flashing LED in 2010 avalanche w/key off
prdjr165
Copper - Posts: 293
Posted: June 24, 2017 at 10:07 AM / IP Logged Link to Post Post Reply Quote prdjr165
what wires do i connect a 2 wire flashing LED light to in a 2010 chevy avalanche so it flashes when i turn the key off ?
Platinum - Posts: 13,725
Posted: June 24, 2017 at 11:45 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Red wire of the LED to a Red or White wire BCM left of steering column, black plug, pins 1, 2, 3, 4. Black wire of the LED to Pink wire BCM left of steering column, lt. green plug, pin 14
If you are not comfortable at the BCM, you can connect the red LED wire to the constant 12volts feed of the radio, should be Red/White. And connect the Black LED wire to the Pink wire on the blue plug of the AC control.
prdjr165
Copper - Posts: 293
Posted: June 24, 2017 at 1:03 PM / IP Logged Link to Post Post Reply Quote prdjr165
awesome-thanks !!!
