DRL Module Wiring, Land Rover LR4 to LR3
elocin671
Member - Posts: 10
Posted: July 28, 2018 at 9:40 PM / IP Logged Link to Post Post Reply Quote elocin671
Hi,
Can anyone help me figure out how to wire up my DRL's. I'm retrofitting 2015 Land Rover LR4 headlights into a 2007 LR3.
The single DRL LED strip from the LR4 has two pins that need positive 12VDC, at different times.
PIN# 2 lights up the strip as Parking lamps, at a lower voltage via its own LED controller.
PIN# 8 lights up the same strip as DRL, at full voltage via its own LED controller.
PIN# 1 is ground
So basically, I need a circuit that will provide DRL Pin# 8 with positive 12V when engine is running, and cut off all power to Pin# 8 when PIN# 2 (+12V) parking lights come on, and when engine is off.
Any help is greatly appreciated. Thanks!
elocin671
Member - Posts: 10
Posted: July 29, 2018 at 9:38 PM / IP Logged Link to Post Post Reply Quote elocin671
Hopefully someone can chime in if my diagram I just made will work or not, or what changes I should make. I did bench test pin 2 and 8 separately, while using pin 1 as ground and they worked as they should.
I will be making my own relay harness, and bypassing the factory wiring for those pins. Is a diode needed?
My concern is to avoid putting 12v+ on PIN 2 and 8 at the SAME time, as this would most likely fry the LED controller since it uses a single strip for DRL and sidelight (parking lights).
DRL Module Wiring, Land Rover LR4 to LR3 -- posted image.
the12volt
Administrator - Posts: 3,959
Posted: July 29, 2018 at 10:13 PM / IP Logged Link to Post Post Reply Quote the12volt
Your diagram looks good to me. If you want to add a diode across the coil of the relay, it won't hurt, but it doesn't look like it's needed.
DRL Module Wiring, Land Rover LR4 to LR3 -- posted image. the12volt • Support the12volt.com
