If you wish to post a reply to this topic, you must first login.
If you are not already registered, you must first register.
Thursday, April 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
4 wires to dome.
Red always live
Off dome pin:
Black is ground from trigger to bulb
Live wire middle and bot when lights on
Live wire door position bot right black/white. But door open all 3 live.
Live wire bottom right black/white when lights off
I use a multi meter says my car is negitve trigger. It also has dim i check when closing the door
