Glo pedals
goomba14
Posted: April 16, 2005 at 7:01 PM / IP Logged
Im wondering if anyone has an idea how to hook up my pedals (a light is included in it), to my electrical system.  They recuire a 12 volts connection to and invertor to witch the 3 pedals hook up to.   So bascically i need to hook up that invertor to a 12 volts line.  Wich way is the easyest and do you know to wich line i should connect. BTW I have a 96 Volkswagen golf.
And if the best way is to get a fresh line from the battery id like to be informed how to do so.
Thx
xTimx
Copper - Posts: 354
Posted: May 27, 2005 at 2:20 AM / IP Logged
i to used to have glo pedals. all i did was hooked it up to my cigarette lighter power and ground, that way you can still use your lighter for people that can smoke if they want to. remember to use a light tester to see which is the power wire. black is ussually ground.
keep in mind that you just have to not have moisture on the pedals. try to keep them clean some how. as dirt and water will short out the glo pedals and you will not be able to bring back the glo. thats why i just went straight to normal pedals that attach to your stock ones. good luck and have fun!
xTimx
