Dimmer for LEDīs, PWM
duunari
Posted: July 24, 2005 at 5:03 PM / IP Logged
I  want to make dimmer something like  this.
I am trying to drive this dimmer my car led gauge lights.
Can anyone tell where i can found schematic and component types and values?
I am trying to make lightning with 3-5 SuperFlux leds and couple of conventional 5mm super bright leds.
I put each led itīs own series resistor, calculated with 13.8v
Mad Scientists
Silver - Posts: 380
Posted: August 06, 2005 at 3:32 PM / IP Logged
It depends on exactly how much power you need, but I think you could probably get away with using a variable resistor like the Radio Shack 25 ohm 3 watt unit # 271-265
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&category%5Fname=CTLG%5F011%5F002%5F011%5F000&product%5fid=271%2D265
Just wire it into the feed line to your LEDs.
Jim
duunari
Posted: August 10, 2005 at 3:24 AM / IP Logged
So simple... Dimmer for LEDīs, PWM -- posted image.
250 ohm 4w works fine... Thanks.
