trouble with fuse
jdiazj1
Member - Posts: 21
Posted: July 25, 2005 at 4:02 PM / IP Logged
hi guys, this is my problem. I want a led to turn on when I turn the outside lights on, I asked for help here and someone suggested for me to tap into the brown wire in the kick panel, I have a 98 navigator. I stripped the cable and wrapped an inline fuse holder and then wrapped another cable from the holder to the led in the back, then grounded the led, then put a 15amp fuse in the fuse holder. problem is this, whenever I turn the outside lights on, it blows the fuse from the truck, not from the fuse holder. what should I do? can I put in a bigger fuse in the truck? what is my problem? if anybody can help me out here, ill appriciate it, thanks
jdawg
customcutlass92
Member - Posts: 26
Posted: July 25, 2005 at 11:39 PM / IP Logged
Put a relay between the tapped wire and the fuse
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
