97 F150 3 door ,Led install advice
kendavis
Posted: October 21, 2005 at 11:32 PM / IP Logged
Hello all.
I am new to the led / neon lighting affects so be gentle.
A while back I purchased a 97 F150 to fix up, and will like to light her up with some LEDs on the inside.
I decided to start off with something small just a lighted toggle switch and some Streetglow LEDs Singles "4 to a pack" 24 LEDs total
I would like to run everthing eventually to the switch to cut off and on at will so,I have to run straight from the battery correct?
What gauge wire and equipment would you recommend?
I would also like to run four of them off of the dome light wiring on that switch just for show when I lock / unlock / open the doors.
menace2sobriety
Silver - Posts: 394
Posted: October 29, 2005 at 1:43 AM / IP Logged
led,s dont take up that much power to run. i'd say a 12 guage wire would work fine. as for the switch yes you can hook it up to the battery but remember to put a inline fuse close to the battery.
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
