F-150 interior lights on
figa1
Posted: November 23, 2005 at 4:54 PM / IP Logged
Hello I have a Ford F-150 year 99’. But I been having some problems with the ceiling en door lights, they never goes off when I close the doors. I tried everything already without success.
Did someone had the same problem in the past, and how did you fix it
Figa1
kenmci
Copper - Posts: 161
Posted: November 23, 2005 at 5:21 PM / IP Logged
check your interior light switch sometime you can override the dome lights to say on.  Does you Door Ajar light come on as well.  Some of the Fords used the latch on the door as a door trigger, so you may have to remove the panel and check it out.  Look for a door pin in the sill, if you don't see one then its built into the door.
