LED fuse indicator light
brianh
Silver - Posts: 518
Posted: January 06, 2003 at 10:40 AM / IP Logged
I want to make a fuse indicator using LEDS. I think if I put a 12 volt LED in parrallel with the fuse I want to monitior,that it will work alright. If someone could double check me I would appreciate it.  Thanks alot Brian
TomEllis
Copper - Posts: 52
Posted: January 06, 2003 at 1:22 PM / IP Logged
Brian,
You do NOT want to put the LED in parallel with the fuse, you need to put the positive side of the LED on the load side of the fuse and the ground side of the LED to ground.
It would look like this:
         + 12 Volts---------Fuse-+-----------Load
                                                   LED
           Ground-------------------+-----------Ground
Sorry about the graphics, I could not past the cad drawing that I did.
I hope you get the idea.
Tom
brianh
Silver - Posts: 518
Posted: January 06, 2003 at 2:45 PM / IP Logged
I got ya. Thanks for the info Brian
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
