Neons take forever to light up. Why?
rinkrat456
Member - Posts: 7
Posted: August 24, 2006 at 8:47 AM / IP Logged
I just installed two of those Pilot 10" neons in each of the footwell of a Honda Civic.  I also have three of them in my GMC Sonoma and I've istalled more in other vehicles.  How I wire them up is simple. I cut off the cigarette lighter plug in and run the negatives straight to the nearest ground. Usually that is also the back of the cigarette lighter.  I run the positive lead to a rocker switch and then to the 12v cigarette lighter positive.  I've done it this way for 3 vehicles.  My problem is that they don't ever light up right away.  I flip the rocker switch, the switch's LED lights up, but it takes a minute or so for the neons to "charge up" if you will.  They'll stay off for roughly a minute and then light up when they feel like it.
I'm wondering why?
Also...about that Honda Civic. It's a 2000 2Dr and when I installed the neons I accidently sparked the positive and negative on the cigarette lighter.  I knew I blew a fuse somewhere.  I found the Accessory outlet fuse(cigarette lighter) and replaced that so the cigarette lighter works now and so do the neons.  Only difference is that the instrument pannel wont light up and I've checked the fuse that says "gauge illumination" and it's good.  Anyone else run into this problem? Driving at night has become a pain because I can't see the gauges until I drive past a light.
Thanks all in advance!
killer sonata
Silver - Posts: 718
Posted: August 24, 2006 at 11:44 PM / IP Logged
do you use a relay when wiring multiple lights together? that could be the issue.
sprawl85
Copper - Posts: 204
Posted: August 26, 2006 at 10:30 PM / IP Logged
check all the fuses. It is easiest to do with a multimeter so that you don't have to pull them all. I remember I blew a radio fuse in a murcury topaz or some doodie and it also had the domelight fuse as a backup for the radio fuse. So both blew and I had to replace both of them.
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
arcangel9
Copper - Posts: 56
Posted: August 30, 2006 at 3:03 PM / IP Logged
Mine sometimes take longer to turn on when the temp in the car is cool.
bellsracer
Silver - Posts: 703
Posted: September 06, 2006 at 5:35 AM / IP Logged
It is the gas inside the neons. In MOST cases they use a noble gas of some sort (such as argon) and a drop of mercury. The ignition system to get the neons working need to be warm in order to get the gas to excite and activate the phosphorus coating on the tube.
When the neon is cold or when they haven't been turned on in a while, the ignition needs to warm up. On certain colors, (usually blue but with all colors) they take longer to light up because the ignition needs more energy to activate it.
As for your gauges, one of the people here think that the light(s) in the gauge cluster burned out. Lights (incandescent) essentially are just a fuse. When one of them goes out, none of the lights work. you'll need to get behind the gauges and replace the bulb that burned out.
silverado42000
Copper - Posts: 65
Posted: September 28, 2006 at 4:21 PM / IP Logged
ive worked on honda before, and for your gauges make sure you check the fuses under the hood, because for some reason honda likes to put them under the hood and under the dash, for the same thing just two fuses for one thing, makes no sense to me why they do it but they do, like split the window motors a fuse for each window, then one for all of em, but thats another story
Neons take forever to light up. Why? -- posted image.
bellsracer
Silver - Posts: 703
Posted: September 28, 2006 at 4:36 PM / IP Logged
Fuses are installed on cars not only to protect components, but to protect the wire and the car itself. A direct short from positive to ground can light up a wire pretty quickly. When I was experimenting with some wiring, I decided to try it out and see how long it took to burn up a wire. from an average 12v car battery, a 14 gauge wire took about 6 seconds before the jacket melted off and got hot enough to light a piece of paper I wrapped around part of the wire.
The fuse is used to stop the wire from staying hot if it should ever short. If short happens inside a component, it's the same thing really, it's to prevent the component from lighting up and damaging the vehicle.
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
