hid headlights
ineed12vhelp
Posted: April 04, 2007 at 7:40 PM / IP Logged
Hi i have a 2000 jeep grandcherokee limited. I just bought this Hid kit of ebay. http:///.com/ebaymotors/dll?ViewItem&viewitem=&item=230109562375
I installed it but the daytime running lights are flickering but when i turn my headlights on they stop. (the day time runing lights are the same as the normal low beam headlights.) Can anyone help me. I guess i could turn off the daytime runing lights but that will cost me 80 dollars to have the dealership reprogram. Can i change some fuses?
rudy1980
Posted: May 07, 2007 at 11:44 PM / IP Logged
I'm no expert, but from what I know most daytime running lights don't operate at full power.  It may not be enough power to keep the ballast on. Try using a relay to power each ballast with the headlight wire as a turn on.
automoglow
Posted: June 01, 2007 at 2:24 AM / IP Logged
Are the daytime running lights different bulbs the the HID kit? If do i would just disconnect the bulbs from the running lights.
Eric
Automoglow
Tripnbeats
Member - Posts: 12
Posted: August 02, 2007 at 1:11 PM / IP Logged
capacitor right where the power line plugs into the ballast.....pm me ill tell u what to get
