what type and size resistor?
bazza2468
Posted: July 29, 2007 at 11:39 AM / IP Logged
Have a problem, I need to fool a truck into thinking the side marker lights are connected. Its a 2007 Mercedes Sprinter the side markers are 12v 3w and there are two per side. Can anyone give me some help or the formula to work out what size ballast resistor I will need to use as Iits starting to drive me crazy what type and size resistor? -- posted image. or is it a case of use the V=IR and work it from that in which case I think I know the answer. Thanks in advance for any help.
Mad Scientists
Silver - Posts: 380
Posted: July 29, 2007 at 12:30 PM / IP Logged
Based strictly on your numbers, you'd use W=V*I, then V=I*R
3 watts = 12v * 0.25 amps (you could also measure this to verify)
12v = 0.25a *  48 ohms per bulb.
I'm guessing 4 bulbs total, for a total draw of 1 amp.. so your resistor size would have to be around 12 ohms.
12 volts = 1 amp * 12 ohms.
Now, the wattage rating of the resistor would be calculated as follows..
12 watts = 12 volts * 1 amp
So.. you'd need either (1) 12 ohm, 12 watt resistor, or (4) 48 ohm 3 watt resistors.
Pretty big resistors.
Jim
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
