adding drl 2007 odyessy ex l
navydavy
Posted: November 05, 2007 at 12:40 PM / IP Logged
Trying to install DRL kit from http://www.automotiveelectronicaccessories.com/aeapn480hd.htm but am concerned where I should connect the "switched" power wire under the hood.  There are four wires total to connect.  Red to the battery, Brown to ground, Green to low beam headlight power (which I am concerned since each headlight seems to have a separate power feed from the fuzebox.) and the final Blue wire - which is supposed to connect to a switched powered feed.  Cannot find a wiring diagram for under the hood.  Any suggestions where I should connect the blue wire (switched) and if there will be a problem with the green wire connecting to both power feeds for the low beams?
Dave
KarTuneMan
Platinum - Posts: 7,056
Posted: November 06, 2007 at 10:53 PM / IP Logged
Get into the fusebox under the hood. There is without a doubt switched 12v in this locatioin!
navydavy
Posted: November 07, 2007 at 12:29 AM / IP Logged
KarTuneMan:  Thanks, I am sure there is a switched 12v there.   Was hoping someone may have a color code for the wires to make it simpler.     Any thoughts on if I will have a problem connecting both hot feeds of my low beam lights to the same wire?
