ported or sealed box?
c.c.autospa
Copper - Posts: 49
Posted: December 16, 2007 at 12:10 PM / IP Logged
I have a 2002 Impala that i want to install 4 12'" Kicker CVX subs in. I would like to know for SPL purposes will the subs sound better in a sealed box or a ported box. I have heard good things about both types of boxes, but I dont really have any knowledge in building boxes. Thanks for you all help.
cedric
aznboi3644
Gold - Posts: 2,600
Posted: December 16, 2007 at 4:48 PM / IP Logged
sealed and SPL do not go together
stevdart
Platinum - Posts: 5,816
Posted: December 16, 2007 at 9:20 PM / IP Logged
Here is the first way I figure the direction to go in when deciding if sealed or vented is best (when I don't know anything else about the person or goals, that is).  This is a quote from Guide: Using WinISD that you'll find stickied above:
Possibly the greatest value of this program is that it will enable you to model a vented box.  Some woofers are best as sealed, others are best as vented.  The EBP tells you the story, although it's not always 100% (hint:  Solobaric wants a sealed, but everybody vents it).  The EBP, you remember, appears in the center of the 'New project' box when you first bring up the new project.  It is simply a calculation of Fs / Qes and a number is shown.  The Kappa sub we were looking at above had a 50.7 EBP, which is within the range of a sealed enclosure.  Higher EBP's generally call for a vented box.  The program determines the best box using this EBP value by default.  But as a working tool, the program allows you to change to whichever you want.
Another good topic for you to read is What is a proper sub box?.
Those subs definitely fit into the ported category.
