bridging amp instructions
mci_sniper
Member - Posts: 16
Posted: February 11, 2008 at 10:33 AM / IP Logged
Im new to car auido and just started 3 weeks ago. can someone explain how the wiring should be done when bridging 2 amps with 2 subs. Thanks sorry if I seem ignorant.
Semper Fi
Platinum - Posts: 13,725
Posted: February 11, 2008 at 12:10 PM / IP Logged
We need to know the brand and model of the amp.  Also we need to know what if the speakers are dual voice coil, single voice coil?  And what is the impedance of the coil(s)?
mci_sniper
Member - Posts: 16
Posted: February 11, 2008 at 1:15 PM / IP Logged
(2)MA Audio MA120XE -Dual 4-Ohm Voice Coils
Lanzar MXA232
Semper Fi
Posted: February 11, 2008 at 4:55 PM / IP Logged
stevdart
Platinum - Posts: 5,816
Posted: February 11, 2008 at 10:03 PM / IP Logged
2 amplifiers, as in one amplifier per sub?  If so, you will need to wire each sub's coils in series for 8 ohms, then bridge one to each respective amp.  You should really use just one of this model amplifier for the two subs, and i am an idiot's post shows you how to see the wiring.
Posted: February 11, 2008 at 11:21 PM / IP Logged
I would have to say that I smooth overlooked that 2 amp thing.  I feel like such an idiot.
n2audio
Copper - Posts: 95
Posted: February 12, 2008 at 8:22 AM / IP Logged
Do this on each amp using the "bridged" connections.
bridging amp instructions -- posted image.
You'll have an 8 ohm load on each amp for 150w rms.
mci_sniper
Member - Posts: 16
Posted: February 12, 2008 at 12:25 PM / IP Logged
which would get the better sound 2 subs one amp with the speakers wired through the other amp or 1 sub per amp and then have the front speakers on one amp and rear speakers on another. thanks for the replies
Semper Fi
n2audio
Copper - Posts: 95
Posted: February 12, 2008 at 12:42 PM / IP Logged
it's a matter of power.
With one amp running both subs you'll get around 100w per sub.
With one amp per sub you'll get about 150w per sub.  It's not a huge difference, but IMO every little bit counts.
jmelton86
Gold - Posts: 1,228
Posted: February 12, 2008 at 6:01 PM / IP Logged
You did say 'get the better sound'. To me, this would give the best sound, although you'll be using the amps for all they've got. You'll still be giving the subs the same amount of power they would be getting by running one to each amp -because you're still running one sub to each amp, while your door/dash speakers can get more power for cleaner sound.
You could do a dual-amp tri-mode setup. ***The amp MUST be tri-mode or tri-way capable, the door/dash speakers MUST have an impedance of 4ohms or greater, the subs MUST have an impedance of 8ohms or greater, the door/dash speakers MUST have passive high-pass crossovers (@ about 80-100Hz) wired in series with the speaker, and the subs MUST have passive low-pass crossovers (@ same freq. as the door/dash speakers) wired in series with the speaker.
1. Have the front speakers connected to amp a in stereo, with sub a wired to the bridged output.
2. Have the rear speakers connected to amp b in stereo, with sub b wired to the bridged output.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
