1997 eclipse wiring
luisandres58
Member - Posts: 6
Posted: March 11, 2008 at 9:10 PM / IP Logged
I need some serious help here! My son bought an Eclipse 1997, but the previous owner did a job on the radio wires! The only one that so far I can identified is the Blue (the 12V+ switched). The rest of the wire scheme is messed up. I can't find the 12V+ constant, illumination, dimmer, etc. According to the site, the 12v+ constant is the RED / black. I tried to see if it has power or not, the meter light did not turn on. Then how do I identify  the wires if the colors are all crossed up? Any idea, anybody?
KarTuneMan
Platinum - Posts: 7,056
Posted: March 11, 2008 at 11:48 PM / IP Logged
This info is from wiremagic, try it.
12V DC Battery(Constant)Red  11 10 amp Engine compartment relay box
Switched AccessoryBlue  12 10 amp Engine compartment relay box
Ground Chassis
Power Antenna WHITE/ black If equipped
Illumination GREEN / WHITE Also BLACK / YELLOW
Left Front + WHITE/ blue For the door speaker and, if equipped, dash speaker.
Left Front - BLACK/ blue For the door speaker and, if equipped, dash speaker.
Right Front + WHITE/ red For the door speaker and, if equipped, dash speaker.
Right Front - BLACK/ red For the door speaker and, if equipped, dash speaker.
Left Rear + Yellow/blue
Left Rear - Gray/blue
Right Rear + Yellow/red
Right Rear - Gray/red
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
