hummer bose problem
bike4ever_
Posted: March 26, 2008 at 6:50 PM / IP Logged
i am having problems putting a pioneer navagation system im getting horrible engine noise. ive used every kind of isolaters ive ran a new ground to the body and grounded the battery to the frame ive used a relay to power up the rem and its still there.
rookie please
Platinum - Posts: 13,720
Posted: March 26, 2008 at 8:27 PM / IP Logged
Are you using the RCA jacks of the radio to provide signal to the bose amp??   If so you need to ground the outer part of the RCA jack coming from your radio.  You only need to ground one of them.  If there are male RCAs on the adapter you are using, you can solder a wire to the shield on the adapter.  And ground the other end of the wire.
http://bcot1.com/images/rca/IMG_9227b.html         The link appears to be dead, it is because of a highlighting issue here.  Notice the end of the line it tries to send you to 9227bl   you need to make it say  9227b.html
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
