mtx rtp251d
djrankin004
Copper - Posts: 154
Posted: April 17, 2008 at 11:05 PM / IP Logged
on the mtx rtp251d amp it is stated the it is a class d amp on the website but there are two channels. does that mean i would bridge a 4 ohm load across it to make it a 2 ohm load ? or is the amp bridgeable?
aznboi3644
Gold - Posts: 2,600
Posted: April 17, 2008 at 11:54 PM / IP Logged
Take another look...it does not have two channels. It says "speaker 1" and "speaker 2"...NOT "Right" or "left"
Just two sets of output terminals that are internally paralleled. Makes for easier wiring of multiple drivers
chillin420
Copper - Posts: 236
Posted: April 18, 2008 at 6:47 PM / IP Logged
correct...  if you wire them both up to one or if you wire one to each speaker connection it will see the same load...  it is one channel in the amp...  just "looks" like two on the outside...
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
94baldwin
Posted: April 18, 2008 at 7:31 PM / IP Logged
that works thanks
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
