2005 dodge magnum w/ navigation
c.c.autospa
Copper - Posts: 49
Posted: June 03, 2008 at 6:23 PM / IP Logged
I'm installing an aftermarket soundsytem on a 2005 Dodge magnum, but I'm not changing the factory navigation. The harness plugged into the back of the navigation screen has a left audio output signal and a right audio output signal, no LF, RF, LR, RR output wires. I'm changing the front door speakers and rear speakers, but the speakers in the dash will remain factory. My question is how do I wire the converter to get an rca signal for the 4-channel amp driving the front door and rear speakers?
cedric
memoriescc
Posted: June 16, 2008 at 12:03 AM / IP Logged
i also trying to hook up a amp to the stock 6disc with nav and the boston stock system... i hear just tap into the rear speakers then i hear since its amp to those speakers it will not sound good any help on how to tap into the wires from the rear deck before it comes out the amp i found the amp but like the post above the colrs dont match what i found for rr + and rr- any help would be appreciated thanks
memoriescc
