vibration and dome/map light
still_walkin
Silver - Posts: 644
Posted: July 06, 2008 at 2:07 AM / IP Logged
I'm having a little problem wit my bass and my map dome light. When I has the bass halfway up or higher my map/dome light vibrates . I tried tighting the screw that holds it down it worked for a little bit then   it started again any suggestions. I have a 1986 cadillac deville 4.1l I'm pushing 2 alpine type r 122d on a audiobahn a2200hct amp
1993 sdv
Alpine 4x6 6x9 5 1/4 swr-10d4
alpine v60
12.5 VGA flip down
Nettop pc w/10" touch screen
78nova
5-re audio 5x7 ,10" sub &
Xtx-500.5
DYohn
Platinum - Posts: 10,741
Posted: July 06, 2008 at 10:30 AM / IP Logged
Remove the assembly, squirt a little expandable foam insulation into the area between the headliner and the roof where it mounts, put it back in while the foam is still wet.
still_walkin
Silver - Posts: 644
Posted: July 06, 2008 at 3:10 PM / IP Logged
Ok ill try that I played with it a little while the bass was up and noticd it has a 1.5 bracket by 3 that slides in then it mounts on the other end wit a screw you think if I put some second skin sound deadner around it it might work .
1993 sdv
alpine v60
12.5 VGA flip down
78nova
Xtx-500.5
