best 6.5 components for 200 250
luckman
Posted: July 27, 2008 at 11:58 PM / IP Logged
I'm building a system and want some opinions on 6.5" component speakers for about $200. I'm using a Rockford Fosgate Punch 25 to Life amp (birthsheet specs. 216W RMS per ch @ 4ohms) and will have 2 sets of Kicker SS6 Mid-bass wired parelled together and seriesed with the componets. In this wiring configuration impedance to the amp will be 8ohms and power output should be about 108W RMS. The components I have narrowed down are:
Rockford Fosgate T162S
Infinity Kappa Perfect 6.1
Boston Accustics Pro 60
I want objective opinions from folks who have heard and/or installed any/all of these components. Also any other options that are in the power/price range would be greatly appreciated.
Thanks, Scott
DYohn
Platinum - Posts: 10,741
Posted: July 28, 2008 at 8:20 AM / IP Logged
Go shopping and listen to them.  Buy the ones you like the most.
haemphyst
Platinum - Posts: 5,059
Posted: July 28, 2008 at 9:43 AM / IP Logged
For that kind of change, buy dedicated drivers, and build...
I've always gotten FAR better results than anything off the shelf could give me.
However, DYohn's advice is far better. You are the guy listening to them, they need to sound good to you. Some here would recommend Focal, where I, on the other hand, can't STAND Focals, with the thin mid-bass, and the screeching highs that the Titanium dome tweeters bring to the party. What I am saying is this: "It's all subjective".
megaman
Copper - Posts: 385
Posted: July 28, 2008 at 11:44 AM / IP Logged
Anyone who says "buy these guys, they are better" are blowin' smoke.  Any audio enthusiast who's got any kind of reputation will say only one thing in selecting your speakers..."Listen to them, and buy the ones you like the most."
Everyone's ears are different.  Don't let anyone tell you different.  Buy the speakers that sound the best to you.  I've lost sales of high-end components to this very idea when the customer likes the sound of the $150 component speakers over the $600 ones.
audiocableguy
Copper - Posts: 630
Posted: July 28, 2008 at 7:48 PM / IP Logged
"will have 2 sets of Kicker SS6 Mid-bass wired parelled together and seriesed with the componets." How do you get 8 ohms from 2 ohms series with 4 ohms?
Are you planning to add crossovers between those m/b and components?
I would think you could Series the kickers(8 ohms)and Parallel with the Comp set to match the sensitivities. If you need more m/b to match, parallel the kickers (change x-over for 2 ohms)and parallel with the comp set. Your amp should be fine with either load.
Haephyst: good call on the Focals!
DYohn
Posted: July 28, 2008 at 10:50 PM / IP Logged
You know I completely missed this before.  WHAT are you trying to do?
luckman
Posted: July 29, 2008 at 8:55 PM / IP Logged
audiocableguy wrote:
"will have 2 sets of Kicker SS6 Mid-bass wired parelled together and in series with the componets." How do you get 8 ohms from 2 ohms series with 4 ohms?
I stand corrected, that would be a six ohm load. I plan on using the amp's high pass filter to cut off any bass response below 50-60Hz. I would then like to build a low pass 2nd order passive x-over for the mid-bass and cut the highs out at 500Hz. And finally use the componets x-over to handle the mids and highs(above 500Hz).
I really appreciate all the comments, but wanted to hear opinions from someone who has accually heard these particular speakers. I know how different speakers sound is very subjective, but car audio professionals should be able to give an objective opinion regardless of their personal tastes. I live 200 miles away from a large city and have no practicle way of listening to any of them, that is why I am asking if anyone(hopefully a professional) has heard these particular speakers and try to give a objectional opinion on these particular speakers. Has any heard these componets Rockford Fosgate T162S , Infinity Kappa Perfect 6.1 , or Boston Accustic Pro 60?
Thanks, Scott
audiocableguy
Copper - Posts: 630
Posted: July 29, 2008 at 9:58 PM / IP Logged
"I plan on using the amp's high pass filter to cut off any bass response below 50-60Hz. I would then like to build a low pass 2nd order passive x-over for the mid-bass and cut the highs out at 500Hz. And finally use the componets x-over to handle the mids and highs(above 500Hz)."
I agree using the amp's HP @ 50-60Hz to the M/B.
500hz is high for a dedicated M/B. Since your looking for
a 6" comp set, 250HZ wouldn't be unreasonable.
"And finally use the componets x-over to handle the mids and highs(above 500Hz)." not sure how you are going to do this. The Comp. X-over is going to be anywhere from 1.2K to 4K and LP the mid and HP the tweeter. You are going to need to build a passive x-over to HP your comp set also. Are you still planning to Series the comp set with the M/B?
luckman
Posted: July 29, 2008 at 10:26 PM / IP Logged
Yes 250Hz may be better and I will build a two way x-over.
Scott
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 11:28 PM / IP Logged
JL AUDIO
Stuey BABE
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
