bad engine whine through speakers
bullseye753
Copper - Posts: 61
Posted: July 29, 2008 at 3:28 AM / IP Logged
As the title implies, I have very bad engine whine coming out of my speakers.. i just installed a jbl cs60.4. it sounds great when its loud, but as soon as the volume goes down the whine is awful. when i rev the engine the pitch goes up. Anyway i can stop this?
Also, when i turn off my car, even when the volume is all the way down i get a huge thump out of the speakers. Are these problems related?
Platinum - Posts: 13,725
Posted: July 29, 2008 at 4:19 AM / IP Logged
My Crystal Ball tells me you have a Pioneer radio.  It also tells me that the following webpage will help you get rid of the noise.
http://bcae1.com/images/rca/temporaryrcashieldrepair.html
The above WILL also fix Alternator "Wire" noise on certain JVC radios as well.
bullseye753
Copper - Posts: 61
Posted: July 29, 2008 at 7:44 AM / IP Logged
Good guess.. but wrong. i have an Alpine.
DYohn
Platinum - Posts: 10,741
Posted: July 29, 2008 at 8:20 AM / IP Logged
Engine whine in an amplifier is commonly caused by a ground loop.  Read the grounding sticky post and be sure to measure your ground return resistance, you want it to be less than one ohm.  Also, check that none of your RCA cables or speaker wires are damaged, and make sure your gain is not too high.
forbidden
Platinum - Posts: 5,354
Posted: July 29, 2008 at 7:39 PM / IP Logged
If it still whines, ask it if it wants some cheese. After that threaten it with the metal recyclers and see if it starts to behave again. After all that, verify that you do not have a pinched rca cable somewhere or that if you have a crossover, the noise is not being induced there.
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 11:14 PM / IP Logged
you need to run your power the oposite side of your rca's going back to the amp and if you already do that you can get a box form walmart r a local car audio place that you put your rca's into that ends the whinning
Stuey BABE
DYohn
Posted: July 29, 2008 at 11:15 PM / IP Logged
forbidden wrote:
If it still whines, ask it if it wants some cheese. .
Rob, you should know that only works with Sony amps.  Sony amps LOVE the cheese.
spookiestylez
Silver - Posts: 531
Posted: July 29, 2008 at 11:30 PM / IP Logged
I prefer a glass for my wine and cheese on the side.
sticky on grounding
rtfm
bullseye753
Copper - Posts: 61
Posted: July 30, 2008 at 1:06 AM / IP Logged
makes sense.. i need to change the side of my rca's. haha whats all this "cheese" talk
s_goodie
Member - Posts: 44
Posted: July 30, 2008 at 1:55 AM / IP Logged
yeah
its an easy fix jsut time consuming but i had the same problem
Stuey BABE
