amp mounting ford 1997 escort
frizkysquirrel
Member - Posts: 47
Posted: August 15, 2008 at 3:21 AM / IP Logged
i have a 1997 ford escort sport.
i was wondering if mounting my amplifier to the back of the fold down seats is a wise idea. if i mount it to them it will be mounted at about the angle of this slash--> / <--on this side.
that means it will be slightly past vertical, kind of upside down.
good idea? bad idea? go with an amp rack instead?
thanks much.
jazzcustom131
Copper - Posts: 175
Posted: August 15, 2008 at 3:48 AM / IP Logged
putting it on that angle would cause all the heat generated internally to stay inside the amp and cook away.
I personally would be found with a sawz-all on the chassis to make room for fans, but that voids warranties and requires a good bit more work.
Amp rack, or find somewhere else to put the amp where it still can expel its own heat.
Greed is for amateurs.
Disorder,chaos,anarchy now THAT is fun!!
megaman
Copper - Posts: 385
Posted: August 15, 2008 at 11:09 AM / IP Logged
I install amps on the back of seats all day long.  If you're mindful to keep air circulation around it, and the amp is not pushed too hard, you'll be fine.  Most people around my parts put the amp on the box, which to me is completely retarded.  Makes it almost impossible for the customer to pull the box out for hauling extra gear, and makes it a quick "grab-n-go" for would be thieves.
frizkysquirrel
Member - Posts: 47
Posted: August 15, 2008 at 11:51 AM / IP Logged
yea, i would never even begin to think about mounting it on my box.
im too unsure about how rigid my box is to even think about that.
the only reason i have brought up this question is because i have had to amps fail in this location lately.
the first one, both were hifonics txi1508D(which could be the problem right there, hifonics haha), was mounted there and went into protect and wouldnt come out and after testing it a few differnt ways came to the conclusion something came loose inside and caused the output to be putting out a DC signal.
so i sent it back got a replacement. this one was worse though. hooked it up gain was slightly over half, i set it with my multimeter and 50 htz, and bass boost was slightly under half. lowpass at about 80 htz, subsonic at 20 htz. i checked my ground resistances and made sure it would be running smoothly. after five minutes playing some song at 28 out of 35 on my HU, i smelt something wrong, stopped the car and popped the trunk and found smoke pouring from the amp, haha. man was i mad. i noticed my inline fuse had blown, so im guessing something went wrong inside and it started drawing excessive current.
well anyways i sent that back and said the heck with hifonics and im getting a orion HCCA-2400D. hopefully will perform better.
jazzcustom131
Copper - Posts: 175
Posted: August 15, 2008 at 4:27 PM / IP Logged
I feel like such a tool, because now that I think about it, one of my amps is located in the same manner in my Explorer.
But now that I fix circuit boards for a living I know better than to do that, but I also have had my JBL amp like that for a year and have had no problems... I'll be moving my amps just because it bugs me, lol :)
If you think that may be a part of the problem, move it, can't hurt.
frizkysquirrel
Member - Posts: 47
Posted: August 15, 2008 at 5:17 PM / IP Logged
yea that is the same way i am, i never had any amps fail there before, but just to know it is not quite a great place to mount it bugs me, lol.
i think i may mount it on a board that will be bolted to the trunk bottom.
frizkysquirrel
Member - Posts: 47
Posted: August 15, 2008 at 5:18 PM / IP Logged
fail there before those two amps, thats what i meant..
i really wish i could edit my posts, lol.
Sunday, October 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
