kicker kx800.2 and 1 dvc 4 ohm sub
proatthagame
Copper - Posts: 65
Posted: September 20, 2008 at 11:51 AM / IP Logged
Kicker KX800.2 and 1 Kicker DVC 4 Ohm Sub. According to sub wiring diagrams i can only wire this DVC 4 ohm sub into either 2 ohm or 8 ohm. How would i hook that up to this amp?
2 x 200W @ 4 ohms (13.8V - 0.085% THD)
2 x 400W @ 2 ohms (13.8V - 0.2% THD)
1 x 800W @ 4 ohms bridged (13.8V - 0.4% THD) - This way? How many watts would be getting to speaker?
2 x 295W @ 4 ohms (Dynamic - 14.4V)
2 x 420W @ 2 ohms (Dynamic - 14.4V)
1 x 840W @ 4 ohms bridged (Dynamic - 14.4V)
S/N Ratio: >95 dB (A-weighted at rated power)
Freq. Response: 20Hz ~ 20kHz (+0/-1 dB)
Fuse: 3 x 40A
Dimensions: 25.75" x 10.13" x 2.5" (65.4cm x 25.7cm x 6.4cm)
Manufactured in 2002
Yours Truly
megaman
Copper - Posts: 385
Posted: September 20, 2008 at 1:07 PM / IP Logged
The amp isn't stable at 2ohms bridged.  You'll need to connect it at 8 ohms bridged, or you can connect one coil bridged, but that's another can of worms we need not get into again. lol.
proatthagame
Copper - Posts: 65
Posted: September 20, 2008 at 1:45 PM / IP Logged
If I traded 2 kicker 4 OHM 12" CVR's for a 4 OHM 12" Kicker CVX.....would that be a good trade. im trying to make more room in my trunk but try to keep the same sound
Yours Truly
megaman
Copper - Posts: 385
Posted: September 20, 2008 at 2:11 PM / IP Logged
no replacement for displacement.  You're gonna lose bass.
proatthagame
Copper - Posts: 65
Posted: September 20, 2008 at 3:57 PM / IP Logged
Yea ive read that post....we dont need to get into that again.....
How do i short a coil, if i was to connect one coil bridged?
Yours Truly
chillin420
Copper - Posts: 236
Posted: September 20, 2008 at 4:07 PM / IP Logged
hook each voice coil up to one channel apiece.  run at 2 ohm stereo.....
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
proatthagame
Copper - Posts: 65
Posted: September 20, 2008 at 4:15 PM / IP Logged
So 750/2 = 375 a coil.
The speaker is 4 ohm. So according to the amp specs, if i ran each coil to a channel then i would get 200 from each channel?
2 x 200W @ 4 ohms (13.8V - 0.085% THD)?
How do i get this with a single 4 ohm coil? How would i wire to go 2 ohm stereo?
Yours Truly
proatthagame
Copper - Posts: 65
Posted: September 22, 2008 at 3:27 PM / IP Logged
Can someone please tell me if im about to hook this up right. I dont wanna f*ck anything up.
The speaker is rated at 750 rms, its a 4 ohm DVC. So i assume each coil has about 375.
If i hook up a coil to each channel then i will get roughly 400 a coil correct and be running 2 ohm stereo?
Yours Truly
