2 Questions
acq810z
Member - Posts: 32
Posted: March 16, 2003 at 6:06 PM / IP Logged
1.  I am planning on buying a Rockford Power 750X 4 channel amp.  Is there going to be any problem running the front channel at 2 ohm and the back at 4 ohm?
2. Totally unrelated;  I have a trunk rattle.  It is actually the lid bouncing up and down not any thing else because I have Brownbread on everything.  It just seems that the spoiler that is on there is a little to heavy and makes the trunk lid bounce when going over bumps.  Like I said, EVERYTHING has at least one layer of brownbread over it.....how do I stop the trunk from bouncing.  It is a 97 Civic EX coupe.
Thanks in advance
~Q
bberman1
Gold - Posts: 2,314
Posted: March 16, 2003 at 6:16 PM / IP Logged
1)  you can run the channel 1,2 @ 2 ohm and 3,4 @ 4ohm there is nothing wrong with that.
2) There are black feet on the trunk lid have you tryed to adjust them yet?
acq810z
Member - Posts: 32
Posted: March 16, 2003 at 6:27 PM / IP Logged
Yeah I have tried they just twist.  they dont screw out or in so there is no height adjustment for them.  it sucks
thanks for the quick post!
~ Q
bberman1
Gold - Posts: 2,314
Posted: March 16, 2003 at 6:36 PM / IP Logged
Well they should go both in and out sounds like they might be broken for some reason. Also the black weather striping around the trunk opening what kind of condition is that in?
acq810z
Member - Posts: 32
Posted: March 16, 2003 at 9:22 PM / IP Logged
The weather strip is in good condition.  I dont know what to say.  I will probably have to jerry rig something to make everything tighter back there.  Thanks.
If you have any other sugestions I am open to them as well.
Thanks Again
~Q
bberman1
Gold - Posts: 2,314
Posted: March 17, 2003 at 6:56 PM / IP Logged
You could consult a body shop they might be able to help you out. Also check the trunk latch and make sure it’s not loose or broken.
