Power wiring question.
donkason
Copper - Posts: 189
Posted: March 17, 2003 at 6:35 PM / IP Logged
I need help with my power wiring. I have a stinger 1 farad cap, 200 amp sting battery relay, and an optima yellow top battery. I was going to wire it like this, power from battery to 125 amp ANL fuse and holder, from fuse holeder to 200 amp stinger relay, from 200 amp relay to stinger 1 farad cap, from 1 farad cap to optima yellow top battery, from battery to fused distribution block, from fused block to both of my amps. Would this set-up be o.k. or does anyone have a better idea. Thanks.
J. Mike Perkins
bdl666
Silver - Posts: 330
Posted: March 17, 2003 at 9:26 PM / IP Logged
Switch the order on the battery and cap. Go like this, first the battery then the fused distribution block and then the cap.And put the cap as close as possible to the amps.
esmith69
Gold - Posts: 1,511
Posted: March 17, 2003 at 9:34 PM / IP Logged
Maybe I'm misreading the original post, but....assuming the power cable has a main fuse located near the battery, wouldn't you go from battery to main fuse to cap to distro. block to the amps?  Shouldn't the cap always go before the distro block?
wvsquirrel
Gold - Posts: 1,237
Posted: March 17, 2003 at 10:38 PM / IP Logged
I've heard mixed things, but from what I've read having the cap after the distro-block is ok. Just make sure it's still within 3 feet of the amp. I was confused at first, but apparently you can run caps off a distro-block and then to ground, and even though it's not directly in-line with the amps, it still works (i.e. 4 way distro-block running 1 cap and 3 amps). I still don't fully understand it, so I keep mine inline with the amp I want using it (after the distro-block).
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
