kicker 12 solo x vs 15 solo baric
joeeeeker
Member - Posts: 41
Posted: January 24, 2009 at 10:43 PM / IP Logged
would appreciate anyones input kicker 12 solo x vs 15 solo baric -- posted image.
j.reed
Copper - Posts: 716
Posted: January 24, 2009 at 11:25 PM / IP Logged
What are you intending this for? SPL, Street beat? Also what kind of power you talking about runnig?
joeeeeker
Member - Posts: 41
Posted: January 25, 2009 at 2:00 AM / IP Logged
SQ. im assuming the solo-x would be better for SPL, but the solobaric would be better for SQ?
soundnsecurity
Gold - Posts: 2,720
Posted: January 25, 2009 at 11:43 AM / IP Logged
neither one is really good for sq but the L5 will probably sound better than the solo x. L5s aren't built very well and never buy a loaded box from kicker because it will probably break apart. and the solo x will need tons of power and will still not sound very good
j.reed
Copper - Posts: 716
Posted: January 25, 2009 at 12:41 PM / IP Logged
Yes the solo x is a SPL sub. It sounds pretty harsh but it will putout very much volume with lots of power. L7s and L5s sound much better and in a sealed box are pretty good for SQ. L7s will get louder than than L5s and are also built better. If you want a street beat set up i would say L7s ported with good power. You would get good sound and very nice volume. With less power and money over the solo x. If you are wanting SPL i would go Solo x and put the power to them. For SQ i would still do L7 sealed because it is built better even though they sound almost exactly like the L5.
joeeeeker
Member - Posts: 41
Posted: January 25, 2009 at 2:47 PM / IP Logged
pushing a jl 1000/1 would you go with a 15" L7 in a ported or a sealed box?
j.reed
Copper - Posts: 716
Posted: January 25, 2009 at 3:53 PM / IP Logged
Im running a Kicker  ZX1000.1 per L7  ported im my Navi. Like i said it come down to what you want. A more true SQ sound or more bass. Ported they still sound great. But its not  true SQ. A sealed box is going to give you more consistant output through the freq range with less output. A ported box is going to be louder but in a  more narrow range. It comes down to you and what you want over all from your system. Playing loud and true SQ are 2 totally different things. If you want good sound and a lot off bass go ported. If you are leaning towards a more true SQ system go sealed.
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
