what bad polarity can do?
sublinux
Copper - Posts: 83
Posted: March 07, 2009 at 12:01 PM / IP Logged
What bad polarity can do? How do you know when polarity is bad? What is the symptom?
haemphyst
Platinum - Posts: 5,059
Posted: March 07, 2009 at 12:37 PM / IP Logged
Polarity? Do you mean connecting the negative terminal of an amplifier to the positive terminal of the speaker? Nothing will happen. The speaker will work as designed. With one speaker, you won't be able to hear incorrect polarity, but with two, there will be a distinct loss of (in the case of multiple subwoofers) bass and focality (in the case of full-range speakers). If both are wired "out of phase" it, again, will be inaudible.
Now, if you mean "polarity" as in connecting a POWER SOURCE like a battery backwards, you COULD completely destroy the device being POWERED, like a deck or amplifier, if the safety devices (i.e. fuses) are bypassed, removed, or over-rated.
sublinux
Copper - Posts: 83
Posted: March 08, 2009 at 12:24 AM / IP Logged
Well, i was talking about speaker.. so if in my car rear speaker (Both 6x9) one got a good polarity and the other have a bad one the sound will be "lazy" ?
forbidden
Platinum - Posts: 5,354
Posted: March 08, 2009 at 12:53 AM / IP Logged
No, it causes one speaker to move in the opposite direction. This primarily shows itself as a loss of bass response. If you are unsure of it, try reversing the leads on one speaker and listening to it, then reverse it back again.
Platinum - Posts: 13,720
Posted: March 08, 2009 at 9:26 AM / IP Logged
The easiest way to check for proper phasing is to balance to left and then balance to right.   If there is bass when either speaker is playing alone, and no bass when balance is in center, one of them does not have proper polarity.
You must turn off all other speakers in the vehicle to properly perform the above procedure.
sublinux
Copper - Posts: 83
Posted: March 08, 2009 at 4:27 PM / IP Logged
Thanks! I just fix my front speakers!
KarTuneMan
Platinum - Posts: 7,056
Posted: March 08, 2009 at 8:34 PM / IP Logged
what about the rears???
sublinux
Copper - Posts: 83
Posted: March 09, 2009 at 9:31 AM / IP Logged
The rears was alerdy good :P Now i got bass from the front WOOT!
Friday, September 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
