rear speakers in deck.
drew454u
Member - Posts: 26
Posted: April 01, 2009 at 10:10 PM / IP Logged
I have a 1997 2 door cutlass supreme and it has JL audio VR 6x9's in the rear deck.  The problem is i have a JL audio W7 12 in the trunk and when  the sub is poundin its not letting the 6x9's return back like they should and distorts the music.  the 6x9's are open to the trunk area and im assuming the pressure from the sub is affecting them. I dont really wanna take them out cause then you cant hear any music is the back seat. its not quite as bad when the seat is folded down but stil happens. sub is in a ported box.  I was thinkin of building a box around the 6x9's then mounting and sealing it them. Any suggestions??
airhed692005
Copper - Posts: 72
Posted: April 02, 2009 at 12:01 AM / IP Logged
I was just going to tell you to seal off the 6x9's so the air from the subs are not going get to them. Thats all you have to do is to build a little box around them and you problem is solved
Ronald Bailey Owner/ Installer of VIBRATION CUSTUM SOUNDS. CUSTOM BOX DESIGNER AND BUILDER
TID-896 7" screen,Amp-BX1206d
4/0power/ground cables
4-12 mofos 12ft3 box tuned 40hz DB:163.1
boogeyman
Silver - Posts: 359
Posted: April 02, 2009 at 7:50 AM / IP Logged
  get some of those foam XTC baffles they are inexpensive and they work well.
soundnsecurity
Gold - Posts: 2,720
Posted: April 02, 2009 at 10:26 PM / IP Logged
seal them off from the trunk or take them out all together are pretty much your only options.
drew454u
Member - Posts: 26
Posted: April 03, 2009 at 7:38 PM / IP Logged
thanks guys looks like im gonna be doing some fab work.
haemphyst
Platinum - Posts: 5,059
Posted: April 03, 2009 at 8:39 PM / IP Logged
Dude... Ten bucks and freight... Problem solved.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 04, 2009 at 12:00 AM / IP Logged
The spiz has spoken.............
Posted: April 04, 2009 at 2:29 AM / IP Logged
Why oh why mix 6x9s and subs? You tell them and explain till you're blue in the face, thank the powers that I don't really get involved anymore, how did I stray to car audio?
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
