orion hcca 15.2 box and amp suggestions
jemster90
Posted: May 07, 2009 at 8:02 PM / IP Logged
Hello,
I am from Australia and recently came into the possession of a Orion HCCA 15.2 subwoofer, a mate had it for a project but had to abandon due to money troubles.
I currently have a 1999 Nissan Pulsar Plus with.
Two Rockford Fosgate P212D4's powered by a Rockford Fosgate Power T5001.bd. Rockford Fosgate Power T162S and T1693C's powered by a American Boss AB-6450.
I wanted to add this third subwoofer to add some more kick as I am currently only hitting 130.2db mostly due to the crappy prefab sealed enclosure I brought for my P212D4's, but I think the Orion HCCA 15.2 should help quite a bit.
I was thinking of purchasing two new amps a Power Acoustik BAMF 4000/1D for the Orion HCCA 15.2 and a BAMF 1200/4 to replace my American Boss amp. Can anyone recommend these amps?
I also would like to know if anyone could suggest some specifications for an enclosure for these subwoofers. I would really like to build a vented enclosure for the Orion HCCA 15.2 as I would like to get as much out of it as possible.
Also a side note that I am trying to do things as cheaply as possable, I have a bit to spend but not lots.
Jemster90
jemster90
Posted: May 10, 2009 at 6:13 PM / IP Logged
Hello,
Just bumping this to get it back on the main page as I am still after an answer to my questions
aznboi3644
Gold - Posts: 2,600
Posted: May 10, 2009 at 8:12 PM / IP Logged
I wouldn't recommend mixing subs.
If you want more output...build a new enclosure.
With two 12s and 500 watts you can do a lot more than that if you don't mind building your own enclosure
Custom Enclosure Design
jemster90
Posted: May 10, 2009 at 10:56 PM / IP Logged
Hello thanks for the reply
Why do you not recommend mixing subs? I've seen other peoples setups and they have different drivers and it sounds good?
Should I just flog off the Rockford P2's and keep the one 15?
Yes I planned to build a new enclosure, three chamber one for each sub. Porting them all instead of my current sealed setup.
