solid versus stranded
dbutcher
Posted: May 19, 2009 at 8:10 PM / IP Logged
This is my first post on this site, so first let me say, wow, there's some really good info here. Now to my question; I have tons of experience with sound systems, just not of the mobile variety. I am aware of the technical reasons for stranded wire in audio applications, but could someone refresh my memory on how this relates to DC in general? I am sprucing up my conversion van a little bit, which requires longer runs than you might think. I have lots of solid wire in my shed, are there any reasons why I shouldn't use it for power, grounds, or remotes?
Platinum - Posts: 13,725
Posted: May 19, 2009 at 8:21 PM / IP Logged
Stranded wire is much more reliable than solid wire in the high vibration environment of a vehicle.  And it is harder to run through the vehicle.  The solid wire will break eventually.
ianarian
Copper - Posts: 516
Posted: May 20, 2009 at 2:09 AM / IP Logged
I use west penn wire for my truck. Its commercial industrial pro audio rated. I twisted all lengths to about 3 twists per inch for noise cancellation. Works perfect-costs nothing.
This is what I do for FUN!
KPierson
Platinum - Posts: 3,527
Posted: May 20, 2009 at 5:13 AM / IP Logged
The general rule of thumb that I follow is if it moves it gets stranded wire, if it is fixed it gets solid wire.
As i am an idiot said, vibration and movement will fatigue solid wire and cause it to fail.
Kevin Pierson
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
