trying to fix my in dash 6 cd changer
annguyen1981
Posted: June 05, 2009 at 7:05 PM / IP Logged
i've got a '03 Ford Ranger that came with an in-dash 6-cd changer.
Long story short:
The arm comes out and up to 'grab' the disc.  After it moves up, it's supposed to deploy three plastic "claws" to hold the disc in place while it's spinning.  These 'claws' are located in the spinning portion of the arm.  These do not deploy at all.
How can I fix this?  Thankz in advance.
Platinum - Posts: 13,726
Posted: June 05, 2009 at 7:47 PM / IP Logged
Was this the initial problem with the unit?
annguyen1981
Posted: June 05, 2009 at 9:04 PM / IP Logged
As far as I know, yes.  I purchased the truck a month ago.  It worked the first couple days, but after that, it never worked again.
Is there a gear that controls that?
Posted: June 05, 2009 at 9:19 PM / IP Logged
I have no idea, I have repaired several of those units but have never seen one with that problem.  I never had a reason to investigate the operation of the spindle.  I can only guess that there is a solenoid that pushes upward on the bottom of the levers, thus forcing them out the top and over the disc.   That deck has a boatload of switches and sensors to let the deck know that certain things are in place and it is OK to perform the next operation.  If I happen to get one in the shop in the next few weeks, I will look around and see if I can get a better idea of how it works.
annguyen1981
Posted: June 05, 2009 at 9:36 PM / IP Logged
Thankz for the help!  :)
annguyen1981
Posted: June 05, 2009 at 9:52 PM / IP Logged
Any tips on how to take apart the changer unit?  I've taken the changer OUT of the deck, but then I see LOTS of springs that I don't wanna screw up.
tommy...
Gold - Posts: 1,901
Posted: June 07, 2009 at 9:18 AM / IP Logged
I see alot of those that either dont read the CD or the door doesnt open to Load/Eject the CD. How hard are the repairs on those units...Obviously depending on what your doing...Just in general. 1-10 diffuculty.
M.E.C.P & First-Class
Posted: June 07, 2009 at 9:28 AM / IP Logged
If the unit will not eject or accept discs, it usually has a disc out of place inside of the unit.  If a disc slides out of place, it will not allow the elevator assembly to move up or down.  These are pretty easy to repair.  Simply look at all of the discs and find the one that has shifted and move it back into place.  Reconnect the unit and test it.
If I get a unit in, I will look and see what all is involved in disassembly of the changer.
tommy...
Gold - Posts: 1,901
Posted: June 09, 2009 at 11:17 AM / IP Logged
Are most of the ford 6 disc the same unit internally...Or a few different designs...?
annguyen1981
Posted: June 09, 2009 at 12:16 PM / IP Logged
i imagine there's a few different designs.
