low bass with 2 amps.
mrnino61
Posted: June 25, 2009 at 1:44 PM / IP Logged
I have a pyle pla2230 amp bridged on an Alpne R-type 12" dual 4ohm sub. Sounds fine alone. I also have a Lanzar 282 amp on 2 Alpne R-type 12" dual 4ohm subs. Sounds great too. Both amps are on lowpass. I have them both on separate remote switches on my dash comming from the same source with a bass knob for the Lanzar, but they are using the same power (4 gage split into 2 10 gage) and ground. Audio input for the lanzar is coming from the pyle output. What can i do to get full power from both amps?
mrnino
mrnino61
Posted: June 25, 2009 at 1:45 PM / IP Logged
This car is a 2003 Ford Crown Vic Police.
mrnino
haemphyst
Platinum - Posts: 5,059
Posted: June 25, 2009 at 3:11 PM / IP Logged
Why do you think you aren't getting full power right now?
soundnsecurity
Gold - Posts: 2,720
Posted: June 25, 2009 at 5:52 PM / IP Logged
one set of subs is probably out of phase from the other. try reversing the speaker wires to your single type R
Platinum - Posts: 13,725
Posted: June 25, 2009 at 7:12 PM / IP Logged
If you can play either amp alone and it sounds OK, and when the other amp comes on, the bass seems to decrease, as Soundnsecurity already stated, the amplfiers are electronically out of phase, or you have a woofer wired incorrectly.  Check both amps to see if either one is equipped with a switch labeled Phase or  0 and 180.  If either amp has such a switch, switch it to the other setting.  If they both have such a switch, only switch one of them.  If no switch on either amp, as stated above reverse the positive and negative wires on the single woofer.
mrnino61
Posted: June 26, 2009 at 7:29 AM / IP Logged
The lanzar has "phase" and the Pyle has "sub sonic". Are they the same?
mrnino
haemphyst
Posted: June 26, 2009 at 8:46 AM / IP Logged
No. Subsonic is a filter that limits how low the amplifier will amplify. It is used with vented enclosures to prevent the woofer system from playing below it's tuning frequency and possibly damaging itself. The control you need is the phase on the Lanzar. Flip it (or change it to watever it ISN'T, right now). Does the bass improve?
Posted: June 26, 2009 at 10:46 AM / IP Logged
That is a good idea Haem, I wish I could come up with some ideas like that.
mrnino61
Posted: June 26, 2009 at 12:43 PM / IP Logged
Good job idiot, ur smart. I turned the Lanzar phase off. Now its working just fine. U guys r great.
mrnino
Monday, February 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
