something isn't right with my system
fortheu
Posted: August 01, 2009 at 2:39 PM / IP Logged
I hooked up all my wiring and etc but when My system comes on it doesnt seem to be pushing the subs hard enough and once in a while ill get a big push for about 2 seconds then it will go softer. Also when I turn the volume on the deck all the way down ill get my subs thumping to no music. I think it might be my RCA cables or the deck itself? Also I can hear my cars idle or throttle in my subs?? Any suggestions or answers?
Jeremy Sult
soundnsecurity
Gold - Posts: 2,720
Posted: August 01, 2009 at 3:04 PM / IP Logged
its probably your rcas. check how you ran them to your amp because they might just be pinched and depending on the quality of your rcas you might just need some better ones. you can also try grounding the outer ring of the rca plug and see if that does anything.
haemphyst
Platinum - Posts: 5,059
Posted: August 01, 2009 at 3:55 PM / IP Logged
Is it a Pioneer deck?
fortheu
Posted: August 01, 2009 at 4:29 PM / IP Logged
yea its a pioneer and someone has told me the deck has given them trouble
Jeremy Sult
Platinum - Posts: 13,726
Posted: August 01, 2009 at 7:16 PM / IP Logged
The same blue line that Haem' posted.     http://bcae1.com/images/rca/temporaryrcashieldrepair.html
