cd player not working for pt cruiser afte
hunk
Member - Posts: 8
Posted: August 27, 2009 at 9:25 PM / IP Logged
I have a 2006 pt cruiser touring edition with a radiator that i just changed out, in the process I disconnected the battery and since then my cd player wont play, but everything else works like the radio, there is just the word cd on the display when in cd mode, it takes and ejects cds but no action on the display. Does
anybody have any idea what the problem is?
cl
custombass
Copper - Posts: 54
Posted: August 27, 2009 at 11:04 PM / IP Logged
Try resetting your head unit. More than likely there is a reset button somewhere on the unit.
Platinum - Posts: 13,725
Posted: August 27, 2009 at 11:44 PM / IP Logged
I can only assume that it is a factory unit. there is probably not a reset button, but disconnecting the battery again may correct your problem.
dp85iroc
Member - Posts: 40
Posted: August 28, 2009 at 2:52 PM / IP Logged
ya def just undo your battery again and see what happens there wont be any reset button
hmmm...thinking is always good...but question are better
hunk
Member - Posts: 8
Posted: August 28, 2009 at 7:16 PM / IP Logged
$I wont be able to get to it til monday, it's not my car. It is a factory deck, hopefully it fixes the problem, I'll let you guys know when i get to it thanks
cl
hunk
Member - Posts: 8
Posted: August 31, 2009 at 8:36 PM / IP Logged
this is pretty lame, but its working now. I was just about to unplug the battery but decided to play with the cd player first. turns out all I had to do was put the cd in, press the power knob on. then press mode until the track and time showed up and voila music. if it was my car I would have had more time to play with it and figured it out. her excuse was she didn't have to do it that way before. oh well thanks anyways guys
cl
Saturday, January 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
