fuse before amp?
bassahaulic
Posted: August 28, 2009 at 1:49 AM / IP Logged
Do yall think it is truly necessary to have a fuse before the amp?
I am considering running my new amp with out a fuse for a few hours just to get some testing in. What do yall think?
Drew Jones
Bassahaulic Productions
drew454u
Member - Posts: 26
Posted: August 28, 2009 at 4:11 AM / IP Logged
there is no way i would ever do it, its there for the safety of a possible fire and to protect the amp. Especially if your gonna be testing the amp im assuming you will be pushin it hard at times. And really how hard is it to install a inline fuse anyways??? takes 5 minutes, and is well worth the peice of mind in my opinion.
Platinum - Posts: 13,725
Posted: August 28, 2009 at 6:12 AM / IP Logged
Do you like the car, and all of the things inside it?  Are you going to be testing it in your garage?  If so, do you like your house?
tommy...
Gold - Posts: 1,901
Posted: August 28, 2009 at 7:52 AM / IP Logged
Like bungee jumping without the bungee...Skydiving without a parachute...Sure some people make it...! Do you really want to play with those odds...???? FUSES ARE SOOOOOO IMPORTANT>>>!!!!!!!!!!
M.E.C.P & First-Class
yimke
Copper - Posts: 417
1 word... FIRE!!
tommy...
Gold - Posts: 1,901
Posted: August 28, 2009 at 7:53 AM / IP Logged
And not just before the amp...But no farther away then 18" away from connection at battery...!!!!!!!!!!!!!!!!!!!!!
KPierson
Platinum - Posts: 3,527
Posted: August 28, 2009 at 10:03 AM / IP Logged
I can't think of a single reason that would justify not installing a fuse - I would never hook an amp up to a car battery inside a car without a fuse mounted right at the battery.
Kevin Pierson
custombass
Copper - Posts: 54
Posted: August 28, 2009 at 12:24 PM / IP Logged
Haste=Waste
