i need to find a 2.5 midrange
radarcontact
Copper - Posts: 54
Posted: September 03, 2009 at 9:08 AM / IP Logged
Anyone know of a decent-priced 3 or 4-ohm ~2" to 2.5" midrange out there?  I want to replace my OEM units and I'm having a hard time locating one.
RadarContact
DYohn
Platinum - Posts: 10,741
Posted: September 03, 2009 at 10:38 AM / IP Logged
Do you mean a speaker that has a 2.5" mounting diameter or a 2.5" diaphragm?  Hmm, let me see, I like a challenge... here's a few options:
Decent 2" dome midrange, another 2" dome midrange that is a little smaller, here's a decent 2" cone full-range that will work as a mid and is cheap to boot, here's an interesting one:  It's an 8-ohm speaker but it'll be just fine in a car,  another version is here I'm not sure what's the difference, this is an outstanding sounding 3" that I have used before as an extended range mid if you can make it fit, I don't know anything about this one but it's interesting... and that was only checking one speaker supplier.  As you can see there are many options out there.
radarcontact
Copper - Posts: 54
Posted: September 03, 2009 at 12:39 PM / IP Logged
I looked at Madisound and saw, and discounted, each of the drivers you referenced above, EXCEPT for the peerless 830983!  Somehow I missed it.  Thanks, I am gonna run the numbers and see what I come up with.  Or, at $14.50/each, I might just buy a few for the hell of it.
Good work Sherlock!
RadarContact
Friday, February 27, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
