power acoustik ovn1-4000d efficiency?
haaze
Posted: September 18, 2009 at 1:11 PM / IP Logged
Power acoustik ovn1-4000d
how much true power is it really putting out?
tommy...
Gold - Posts: 1,901
Posted: September 18, 2009 at 7:23 PM / IP Logged
I think its going to differ...depending on what ohm load the amp will see...! Do you not believe the manufactures specs...? What kind of subs are you planning on using...?
Amplifier ClassD
Number of Channels1 - Mono
RMS Power (4 ohms)1200 watts x 1 channel
RMS Power (2 ohms)1700 watts x 1 channel
RMS Power (1 ohm)2200 watts x 1 channel
Bridged RMS PowerN/A
Total RMS Power Output2200 watts
Peak Power Output4000 watts x 1 channel
Total Peak Power Output4000 watts
Maximum Input Gauge Size1/0
Minimum Impedance Unbridged1 ohm
Minimum Impedance BridgedN/A
THD at Rated RMS Power.5%
Speaker Level InputsNo
Preamp Outputs1 pair
Built-in CrossoverLow-pass (LP)
High-Pass Crossover FrequencyN/A
Low-Pass Crossover Frequency40 - 200 Hz
Subsonic Filter20 - 50 Hz
Signal-to-Noise Ratio100 dB
Channel SeparationN/A
Bass Boost0 - 18 dB
Bass/Gain RemoteYes
Fan CooledNo
Fuse RatingN/A
M.E.C.P & First-Class
haemphyst
Platinum - Posts: 5,059
Posted: September 18, 2009 at 11:50 PM / IP Logged
I think he's asking about MAX power... That's only going to happen at the amp's maximum load, which will also be the amp's minimum efficiency.
That being said, it's DAMN sure not putting out 4kW. How big are the fuses in the end?
haaze
Posted: September 19, 2009 at 8:24 PM / IP Logged
i got 2 ascendant audio chaos 12s off a shuriken bt100
my buddy has the same subs with an addictive audio 1000.1 and his hits harder than mine
leading me to believe ethier my manufactures claim was overratted or his was under rated
Platinum - Posts: 13,726
Posted: September 19, 2009 at 9:36 PM / IP Logged
There are so many other variables beside the amplifiers power.  Are they even the same style of vehicles?  Are the subs in identical boxes?
tommy...
Gold - Posts: 1,901
Posted: September 19, 2009 at 11:59 PM / IP Logged
He probably has BoxRox(tm)...!
