4 ohm car speaker on 2 ohm load
daniel gt1
Copper - Posts: 55
Posted: November 05, 2009 at 12:59 PM / IP Logged
wat would be the outcome if you wire, a 4 ohm car speaker on a 2 ohm load on a 4 channel amp?..would u get cleaner sound..or would you cause damage to the amp?
DYohn
Platinum - Posts: 10,741
Posted: November 05, 2009 at 1:06 PM / IP Logged
A 4-ohm speaker is a 4-ohm load.  If you place two 4-ohm speakers in parallel you present a 2-ohm load to the amplifier.  What exactly are you trying to do?
daniel gt1
Copper - Posts: 55
Posted: November 05, 2009 at 1:15 PM / IP Logged
i know how 2 wire in parallel and series etc...i wanna run 2 6x9s and 2 6.5s on a 4 channel amp...cud i do this ?
mrarff
Copper - Posts: 71
Posted: November 05, 2009 at 2:02 PM / IP Logged
 You may do anything you wish Grasshopper...it  ABSOLUTLY depends on the power rating of both the amp AND your speakers. 50 watt rms speakers generally won't last very long or sound very well connected to a 200 watt/channel(rms) amp. Match your speakers to your amp. And also, spend some time reading these posts/topics/replys, all of them in general. You really can learn alot without ever asking/typing a thing.....If it sounds good to you...then it IS good.
"That'll get ya 10 in Leavenworth,11 in Twelveworth, or 5 & 10 in Woolworth". Groucho Marx
daniel gt1
Copper - Posts: 55
Posted: November 05, 2009 at 2:12 PM / IP Logged
yea i know i dont hav to post anything,regardless if the answer is already here, but its alwayz a recommended way of i postin somthing i dont know. :)
I'm sure you guys heard of "SPAWN" in Trinidad and Tobago. Our guys in our country DONT use 4 channel amps for mids especially. Why? because use a power 2 channel amp eg : RF 800.2, Soundstream PCA 880.2 or even a Precision Power 2 channel amp..wWe then BRIDGE the speakers, for more power and maxing them out for a loud mids setup.
stevdart
Platinum - Posts: 5,816
Posted: November 05, 2009 at 2:49 PM / IP Logged
The only thing that makes sense out of what you've said here, daniel gt1, is that you might be wondering if a 4 ohm load is harder on an amp than a 2 ohm load.  It is not; it is easier.  4 ohms is the lighter load.  So of course you can connect four speakers to a 4-channel amp.  That is the best way to do it.
daniel gt1
Copper - Posts: 55
Posted: November 05, 2009 at 3:54 PM / IP Logged
I GUESS YOU'RE ACCURATE ON THAT STATEMENT, BUT I UNDERSTAND NOW..THX !! :)
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
