wiring kicker comp 10
menara024
Member - Posts: 19
Posted: March 21, 2010 at 10:25 AM / IP Logged
i just got two kicker comp single voice coil subs but two on outside are 4 ohm and one in middle in 8 ohm  how could i wiring these subs together bestly
menara024
Member - Posts: 19
Posted: March 21, 2010 at 10:47 AM / IP Logged
hookng up to sony explode xm-2200gtx
diamondaudioguy
Member - Posts: 17
Posted: March 21, 2010 at 11:09 AM / IP Logged
Ok just my opinion but I would lose the 8ohm sub with that amp its not going to be very effeicant and you will get more power with two subs than u will with three "with that amp" if u were to wire all. Three I would say u would prob have to wire the 8ohm sub in parrell I would really like to know myself if this can be done without two subs receiving more power than the third.just lookin over the specs of ur amp I'm fairly confident in saying that is not the right amp for what ur wanting to do.sorry this is. So long lol
diamondaudioguy
Member - Posts: 17
Posted: March 21, 2010 at 11:14 AM / IP Logged
Please disregard my previous comment I totally misread your question.I thought u had three subs,two 4ohm and one 8ohm I appoligize.
Platinum - Posts: 13,725
Posted: March 21, 2010 at 1:34 PM / IP Logged
I too am confused by your original post.  If you have 3 woofers, 2 4 ohm and 1 8 ohm, and you have an enclosure with 3 separate chambers, This is the only way to properly connect 3 drivers to that amp and still achieve maximum power from the amp.  Bridge the 8 ohm driver and connect one 4 ohm driver to each channel.  The amp will see a 4 ohm mono load and produce maximum power.  The 8 ohm driver which is a bit less efficient than the 4 ohm will see twice the power as the 4 ohm drivers.  You must have 3 separate chambers for this to work for you.
menara024
Member - Posts: 19
Posted: March 21, 2010 at 5:38 PM / IP Logged
 do have three seperate channels so  hook up the 8 ohm bridged to the amp and then each 4 ohm to on channel each?? i this right "iam an idiot"??
menara024
Member - Posts: 19
Posted: March 21, 2010 at 7:17 PM / IP Logged
i mean three seperat chambers
Posted: March 21, 2010 at 7:18 PM / IP Logged
That is correct.  You must have a 3 chambered enclosure.
menara024
Member - Posts: 19
Posted: March 21, 2010 at 7:20 PM / IP Logged
to revise my orginal  post i am trying to hook up there kicker comp single voice coil subs to a sony explode xm-2200gtx
menara024
Member - Posts: 19
Posted: March 21, 2010 at 7:21 PM / IP Logged
 i do have a seperate chambers thanks
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
