Posted: April 14, 2003 at 3:55 PM / IP Logged
Posted: April 14, 2003 at 9:29 PM / IP Logged
Posted: April 14, 2003 at 9:34 PM / IP Logged
Posted: April 14, 2003 at 9:36 PM / IP Logged
Posted: April 14, 2003 at 9:39 PM / IP Logged
Posted: April 14, 2003 at 9:48 PM / IP Logged
Posted: April 14, 2003 at 10:17 PM / IP Logged
Posted: April 14, 2003 at 10:34 PM / IP Logged
Posted: April 14, 2003 at 11:06 PM / IP Logged
Posted: April 15, 2003 at 2:24 PM / IP Logged
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The Wal Mart harness (female plug) will attatch to your factory wiring plug (the one that goes into the factory headunit) and you will have the other end of it with the bare wires.
As long as you have the wiring diagram for the Sony CD player harness and the Wal Mart harness, then cut the end off the Sony harness and splice it into the bare wires of the Wal Mart harness. Make sure you are cutting the end off that does not attatch to the CD player (you want to cut off the part that would have connected with the Lebarron's wiring), you'll still need the CD player connection to conect to the CD player in a miunute! Make sure to leave about an inch or 2 of wire when you cut, so that if you make a mistake you can splice it back together. You will need to match the wire functions from the 2 wiring diagrams (the Sony diagram and the Wal Mart harness diagram), not necessarily the colors! What you should end up with is...
Factory wiring --> (no splice needed, use the connectors) --> Wal Mart harness --> (splice needed, wire to wire based on diagrams) --> Sony harness --> CD player
You did the right thing getting the Walmart harness, that way you wont have to cut any "factory wiring" and can easily replace the old headunit if you sell the car. Most aftermarket headunits come with their own harnesses, but they are bare on the other end like the Wal Mart one you got. That makes most people believe that they have to cut the factory wiring to make it work, when if fact all you need is another harness to splice into (like you've already got). More than likely Circuit City had the Exact installation harness for your old lebarron and used it instead of this way, and that's why it had the connector on the other end as well (because it was specifically designed to integrate with the lebarron). Those harnesses can be hard to find unless you're an installer, which is why you're left doing it this way.
Please let me know if I've made you more confused!
