94 chevy suburban deck
desh187
Copper - Posts: 310
Posted: October 25, 2010 at 6:23 PM / IP Logged
Do i need an amp-tuner bypass kit on a 94 Chevy Suburban to install a deck and if i do,where is the amp located.
Platinum - Posts: 13,725
Posted: October 25, 2010 at 8:44 PM / IP Logged
Sit in the driver seat, place your right foot on the accelerator pedal.  Directly above your shin, the amp is mounted to a bar that goes from the bottom edge of the dash to the firewall of the truck.  Remove the 7mm screws from the dash end and the firewall end of that bracket, the amp should drop straight down.  A Metra 70-1858 will plug into the wires that you remove from the top of the amp.
There may be 3 screws, but that is where the tuner/amp is located.
