head unit only powers up for 2 seconds?
4pac
Member - Posts: 9
Posted: February 05, 2011 at 5:08 PM / IP Logged
 Hi all. please forgive me if I,ve posted in the wrong section of the forum,
A friend of mine bought a new stereo for his Audi A3. He took it somewhere to be fitted and the geezer at the garage said the new head unit powered up for a short period then switched itself off. His conclusion was that the head unit was knackered so it got sent back to the supplier. The unit was tested at the factory and worked perfectly.
I went round to my friends today & tried to refit the "original" head unit but the same thing happened, it would power up for a couple of seconds then switch off.
If I disconect the power lead and wait for a few seconds, when i plug it back in the head unit will power up again but only for 2 seconds.
Does anybody have an idea what could cause this?
(I,m not sure if the bloke at the garage altered any of the wiring, would the head unit do this if it wasn,t earthed I wonder?)
Thanks for any input you could give,
Andy
Platinum - Posts: 13,714
Posted: February 06, 2011 at 7:47 AM / IP Logged
No earth would = no power up at all.  You will need to get a volt meter and verify that the unit is getting adequate power on both the constant and the switched power wires.  And also check earth as well.
4pac
Member - Posts: 9
Posted: February 06, 2011 at 10:25 AM / IP Logged
Thanks mate I,ll nip out and have a prod round at the wires, Cheers.
4pac
Member - Posts: 9
Posted: February 06, 2011 at 7:38 PM / IP Logged
Had a poke round with the multimeter & I,m geting a contsant 12volts from the wires, think the original head unit must be damaged thats why it keeps shutting down. I get the new head unit backtomorrow, hopefully this will work ok. fingers crossed.
4pac
Member - Posts: 9
Posted: February 06, 2011 at 7:53 PM / IP Logged
PS
Well done guys, I entered the same problem on 2 forums & you were the first to reply. I know where I,ll come back to in future.
4pac
Member - Posts: 9
Posted: February 06, 2011 at 7:54 PM / IP Logged
MINT head unit only powers up for 2 seconds? -- posted image.
Posted: February 06, 2011 at 8:21 PM / IP Logged
All modern day radios need 2 power sources.  The yellow wire of the deck should receive constant power.  The red wire of the deck needs to be supplied with 12 volts only when the key is on.
4pac
Member - Posts: 9
Posted: February 07, 2011 at 6:35 AM / IP Logged
The car only has one wire that supplies power & that power is constant, there is no wire from a swiched power source. (I also thought that was strange)
Would it be ok to wire both the red & yellow wires to the constant power source?
KPierson
Platinum - Posts: 3,527
Posted: February 07, 2011 at 7:37 AM / IP Logged
If you wire red and yellow to constant power the radio will not shut off with the ignition.  You'll need to manually turn it off every time the car is turned off.  Not a good solution.  If there isn't a switched ignition feed in the harness then you would be best off to make one from the ignition wiring.  What year is the A3?
Kevin Pierson
4pac
Member - Posts: 9
Posted: February 07, 2011 at 7:52 AM / IP Logged
Its a 2004 mate.
Friday, July 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
