Posted: April 23, 2003 at 7:35 PM / IP Logged
Posted: April 23, 2003 at 10:45 PM / IP Logged
Monday, May 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
You could also wire in Stereo with a 1ohm load at each channel and throw 1500RMS to each speaker, but be careful not to have the gains too high with this type of configuration as you would be running above the RMS rating of the sub. WARNING... If you wire like this, you are running a serious risk of blowing your subs, even with the gains turned down. Here's how to wire one 2ohm DVC per channel into a 1ohm load (each sub would look like this)...
You'll never get the 0.5ohm load since (according to the Boss site) you have to be in a Stereo configuration (not Bridged) to get the 2000RMSx2. But that wouldn't be a good idea anyway since your sub's Peak rating is 2000 watts!
