1995 toyota camry radio wiring australia
rlexyd
Posted: May 18, 2011 at 2:02 AM / IP Logged
Hi all,
I am replacing the original Radio in my 1995 Toyota Camry (Australia) to a newer stereo.
I read the wiring diagram on this website regarding the same model car, but it's NOT like my original wiring??!!
I tried for two days now and still can't figure it out.
The problem is I cannot seem to locate the 12v Constant Wire, it doesn't seem to exist?? Even though the original radio kept the memory in it so It had to have existed!!
Guessing the wiring colours are different because it might have been made slightly different for US and AUS Version.
The Speakers are connected fine..(Blue, Light Blue, Yellow, Purple, Pink, Blue, Red and White)..
Black is Earth.
I am now left with these coloured wires...(RED, GREEN and White with Black Stripe), but none of them are the constant.
I found the ignition which was (Navy with Red Stripe).
Please if someone can advise.
Regrads,
blanx218
Silver - Posts: 654
Posted: May 18, 2011 at 11:34 PM / IP Logged
Did you check the radio fuse? Sounds like you may have inadvertantly blown the fuse while wiring it up. If the fuse is good and there is still not any constant power, you could always run a new lead from the battery, just make sure to fuse it as close to the battery as you can.
rlexyd
Posted: May 18, 2011 at 11:51 PM / IP Logged
Hi,
Thanks for your reply.
The fuse on the radio is fine, it plays it just doesn't hold memory because there doesn't see to be a constant wire, guessing the original radio might have had an internal battery or something which made it keep the memory.
I managed to connect it today finally, I decided to tap into the constant wire for the (Hazard Switch) which is on top of the radio and that seems to have done the trick and saved me from running and lead from the battery!!
Do you think I would need to take it apart again and add a fuse or will it be safe??
Regards,
91stt
Silver - Posts: 564
Posted: May 19, 2011 at 1:47 AM / IP Logged
blanx218 is not talking about the fuse in the radio, he is referring to the fuse in the fusebox under the dash. It seems you may have blown the fuse while testing for the wire. You are better off replacing the fuse and than wire it up properly.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
rlexyd
Posted: May 19, 2011 at 3:37 AM / IP Logged
Hi,
I did check all the fuses in the fusebox under the dash as well and they're fine!
I thought if the radio/cigarette lighter fuse was blown, the radio would not have worked at all, so I would assume if the radio was working than the fuse should have been ok.
It's all back on and working fine, I just wanted to find out if I should take the radio out again and put a fuse between the constant and the radio?
Regards,
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
