speakers not working
dhickey
Posted: June 03, 2011 at 2:34 AM / IP Logged
I have a 2000 GMC Sierra 1500.  I just bought a pair of JL Audio 650-CSi.  I installed the passenger door, checked sound, good to go.  I moved on to the drivers door, installed it, no sound.  Not out of either front nor the rear speakers.  Stereo works, st comes on and off for stations.  Switch stations works everything except speakers.
I don't have amps, and it is the stock radio.  These speakers are my first addition to the truck.
Thanks for helpin!!!
itsyuk
Silver - Posts: 505
Posted: June 03, 2011 at 3:09 AM / IP Logged
sounds like somewhere along the way you may have gotten a speaker wire shorted to ground and the radio has protected itself by shutting off the internal amp.double check the wires on the second crossover. is there a fray or a pair of wires swapped?
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
dhickey
Posted: June 03, 2011 at 3:24 AM / IP Logged
wires all look good.  If it did trip, possible when cutting to change speaker connectors, how can i reset that?
DYohn
Platinum - Posts: 10,741
Posted: June 04, 2011 at 2:17 PM / IP Logged
Let me guess: you did this with the battery connected or worse with the radio on?  If so the earlier poster is correct and you have caused the radio to go into protection.  If it doesn't come back with a power cycle, then try momentarily disconnecting the battery.  If that doesn't work you might have fried the amps inside the radio.
itsyuk
Silver - Posts: 505
Posted: June 04, 2011 at 11:23 PM / IP Logged
if you try that and it doesnt work.....try unhooking the new speakers where the radio hooks to the crossover and see if the rear speakers will work once again?
yuk
jmholden46
Member - Posts: 12
Posted: June 08, 2011 at 8:48 PM / IP Logged
Any luck with your stereo Yet?
-BiG J-
