2 amp
vxliquid
Posted: April 26, 2003 at 5:10 PM / IP Logged
Can someone plz post an image or explain how wire the RCA's in a 2 amp config?
vxliquid
Posted: April 26, 2003 at 5:21 PM / IP Logged
Lets say that I only have one set of RCa's comming out of the radio
Big Purds
Silver - Posts: 574
Posted: April 27, 2003 at 1:13 AM / IP Logged
you have to buy a set of splitters that have a single male end and two female ends...then run one set to each amp...
Sound Pressure
Silver - Posts: 711
Posted: April 27, 2003 at 1:14 AM / IP Logged
Do you have an input and output on one of the amps for rca's? If so hook up your inputs from your headunit into that and hookup your output rca's from that amp into the input rca on the other amp. That is a daisy chain. If not then hook up a y male to two female connector and split the rca signal that way.
Sound Pressure
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
