0 gauge copper or aluminum?
deeryders
Copper - Posts: 97
Posted: February 03, 2012 at 7:12 PM / IP Logged
Which one will let more current. I have always been under the impression copper is the best and nothing but, however now some people or telling me other wise. Thanks Guys.
MECP Certified
Dont Ground Out!!!
Platinum - Posts: 13,725
Posted: February 03, 2012 at 9:30 PM / IP Logged
If you value your vehicle, use only copper wire.
equilibrium1990
Copper - Posts: 50
Posted: February 03, 2012 at 10:31 PM / IP Logged
I have heard that using CCA(Copper Coated Aluminum) 0 Gauge is equivalent to using 2 Gauge true copper, Shame that I just got 50 feet of 0Ga CCA :-(
deeryders
Copper - Posts: 97
Posted: February 03, 2012 at 11:03 PM / IP Logged
whats wrong with aluminum?
MECP Certified
Dont Ground Out!!!
91stt
Silver - Posts: 564
Posted: February 03, 2012 at 11:13 PM / IP Logged
Copper is the second least resistive material. Only silver possess a lower resistivity.
As a general rule, copper clad aluminum needs to be two gauge sizes larger to pass the same amount of current as copper.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
haemphyst
Platinum - Posts: 5,059
Posted: February 04, 2012 at 9:44 AM / IP Logged
I second the question... If the aluminum wire is adequately sized, then there is no difference between aluminum or copper. They're both perfectly usable conductors.
As long as the proper concessions are made, then I think that the "if you value your vehicle" statement is a little bit strong. :P
oldspark
Gold - Posts: 4,913
Posted: February 04, 2012 at 3:33 PM / IP Logged
But you need a larger gauge of Al.
To answer the OP - copper. Just compare electrical conductivity tables.
Aluminium conducts more per weight, but not per gauge.
And aluminium fatigues & breaks easier, i trickier to terminate etc,
COPPER!
DYohn
Platinum - Posts: 10,741
Posted: February 04, 2012 at 6:55 PM / IP Logged
In general, don't use aluminum in low-voltage high-current applications.
equilibrium1990
Copper - Posts: 50
Posted: February 05, 2012 at 4:16 AM / IP Logged
To lightly jack the OP's thread, Will it be ok to use the 50foot roll of 0Gauge CCA I have just purchased for running 1500-1600RMS off? I currently have 4Gauge copper run and it powers it nicely, I just wanted to put 0Gauge in for piece of mind.
oldspark
Gold - Posts: 4,913
Posted: February 07, 2012 at 3:19 AM / IP Logged
In terms of conductivity:
Conductivity:
CCA = 2.74 Ohms cm (63)
Cu = 1.72 Ohms cm (100)
Resistance of CCA = 2.74/1.74 = 1.6 that of Cu. (CCA has 1.74/2.74 = 63% the conductivity of Cu.)
Dimensions:
0G = 8.25246 mmD = 53.5 mm2
4G = 5.18922mmD = 21.14 mm2
0G has 53.5/21.14 = 2.53 times the area of 4G. (Conductivity is proportional to area.)
2.53 x .63 = 1.6 x the conductivity (of 0G CCA for 4G Cu).
(Or 1/1.6 = 0.63 the resistance of 4G Cu.)
So, electrically you are better off with the CCA.
Whether you should use CCA is another matter.
