mono amp wiring input
hortonguy
Member - Posts: 6
Posted: March 09, 2012 at 4:00 PM / IP Logged
I DO HAVE ONE MORE QUESTION THE AMP IS A MONO AMP BUT HAS LEFT AND RIGHT INPUTS DO I USE A Y CABLE AND RUN BOTH LEFT AND RIGHT OUTPUTS FROM THE HEAD UNIT TO ONE INPUT?IF SO WHICH ONE AND WHAT IS THE PURPOSE OF THE OTHER? I KNOW THE SPEAKER OUT PUTS ARE WIRED PARALLEL SO IT DOESN'T. MATTER WHICH ONE OF THOSE YOU USE. mono amp wiring input -- posted image.
DYohn
Platinum - Posts: 10,741
Posted: March 09, 2012 at 5:48 PM / IP Logged
First off, please do not type in all caps.  Secondly, in general you only need to use one input if it's a mono amp.  What is the make/model?
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
