11 subaru legacy
rutcgr18
Member - Posts: 45
Posted: June 13, 2012 at 9:58 PM / IP Logged
I have 11 subaru legacy. I wanted to put my police scanner it the pocket i have marked in the attached images. Do they make a kit for this? I just need a single din kit. The scanner has a din sleeve Or does anyone on the site do some good fab work?
Mike
11 subaru legacy -- posted image.
Platinum - Posts: 13,725
Posted: June 13, 2012 at 11:51 PM / IP Logged
rutcgr18
Member - Posts: 45
Posted: June 14, 2012 at 4:07 PM / IP Logged
i am an idiot wrote:
http://www.metraonline.com/part/89-00-9031
Thanks but i am not good at doing plastic fab work.
Mike
Posted: June 14, 2012 at 8:43 PM / IP Logged
The back side of the sheet has a grid pattern on it.  Simply figure out how big you need the piece, score it with a razor knife and break it.  Then figure out the size of the opening you need, and score it too.  You can not break it so you will have to cut all the way through.
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
